Overview
This is a VI that will calculate absolute accuracy of a DAQ device if input with the data from the specifications.
Description
Enter the appropriate data into the chart and have your absolute accuracy calculated.
Requirements
Software
Additional Information or References
It doesn't work
Hi Dgalanis,
What device were you trying to calculate for? What issues did you run into?
Dustin
Thanks for making this!
Number of readings in the Spec sheets lately seems to be 100 so might want to change the default settings to reflect that.
