Example Code
DAQmx AI read based on Device Serial Number
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI allows the user to read AI from a device that has a known serial number regardless of device name changing or for example in a CompactDAQ changing slot.
Description
This example shows how to read a DAQmx AI channel based on the device's serial number, so in case the user has a system where devices can change slots in a cDAQ (in case of C Series modules for example), the device is changed from USB port or simply change device names, the acquisition will still work correctly. This example also contains a VI in which the user can actually see which devices are present at the moment in his system and their corresponding serial numbers, so he can begin to work with the examples with no delays.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
1. Obtain the desired device serial number by using FindSerialN.VI (subVI)
2. Insert the serial into the Serial Number text field.
3. Select the AI channel to read, rate and samples per channel
4. Start the VI
5. Stop the VI.
Additional Information or References
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
Comments
Todd S.
NI Employee (retired)
on
thanks for posting.  please add "LabVIEW" to your tags and rename your attachment to include the LabVIEW version.  "_lvXX.vi" would be fine.
Todd S.
LabVIEW Community Manager
