Overview
Demonstrates how to change a solenoid state then acquire data for a set amount of time and finally fetch them into analyze state
Description:
This VI is configured to change a solenoid from off to on and then acquire data for a set amount of time (provided it is a short amount of time that will not overflow the buffer). This data is then fetched off the buffer and passed into an analyze state.
Steps to implement or execute code
To implement this example:
- Define the physical channels to be used
- Set the rate and milliseconds to wait
- Run the VI
- (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
- Install the required software.
- Connect the DAQ hardware that supports the DIO and Analog Input features
- Confirm the connection with the MAX with TestPanel
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Digital IO and Analog Input Module
