DAQmx Acquire with Multiple Channel Input Ranges
Overview
  This VI shows how to use DAQmx to acquire data from multiple channels each with their own Input Range.
Description
This code shows how to use DAQmx to acquire data from multiple channels each with their own Input Range. The code also displays the data of each channel separately.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Configure the parameter for the right channel and device
  2. Connect your hardware appropriately
  3. Run the VI
Additional Information or References
 Front Panel
Block Diagram
Comments
I am new to labview. I am wondering will this vi simultaneously read from two or more channels?
