Overview
This example works to split the data between multiple filesas Comb filters when logging data using DAQmx TDMS logging.
Description
When logging data using DAQmx TDMS logging, splitting the data between multiple files can make file sizes more manageable. TDMS file splitting was first supported in DAQmx 9.3. TDMS file splitting is enabled with the use of a property node.
Requirements
Software
Hardware
Additional Information or References
