Example Code
DIAdem Curve Limit Testing
Products and Environment
    Software
  • Diadem
Code and Documents
Overview
This example shows how to script and display a limit test between two curves. This allows more complex limit testing such as windowed limits and displays them for inspection.
Description
Often it is useful to have more complex limit testing and display the results. For example rather than a fixed limit across the full range you may want a varying limit.
This example:
  1. Loads the crash data that ships with DIAdem.
  2. Calculates the resultant of the XYZ acceleration.
  3. Creates the channel to use as the maximum limit.
  4. Creates a channel which has no values inside the limits and matching values outside the values.
  5. A report is then loaded which has curves to show the limits, the data curve and then the curve of outside values.
All of this is automated using the included script.
Requirements
  • DIAdem 2012 (or compatible)
  1. Unzip the attached files.
  2. Open and run the script included.
Additional Information or Reference
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
