Introduction
This vbs file is designed to show how DIAdem scripting can be used to do a number of different tasks.
These tasks include
Steps to Complete and run
1) Save the .vbs file and .tdv into the same file location.
2) Load the script file into DIAdem and run the script.
3) Change line 14 to be the folder location where the .vbs and .tdv files are located.
4) Run the script file.
5) Select a .tdm file when the File Dialog popup appears.
6) The view panel shall be displayed.
7) Select channel data, and drag these onto the View Panel. At this point, the data shall be displayed.
😎 Select two cursor positions within the data.
9) Click the end iteraction button under File > End Interaction, or by clicking the hand with the red stop.
10) This will produce a messagebox popup that contains the gradient (dY/dX) between the two cursors, (X1, Y1) cursor positions, (X2, Y2) cursor positions
11) Two new channels are created, storing this cursor data.
12) A new dialog popup will appear to ask you to save the new .tdm file.
Additional Notes
This script was produced in DIAdem 11.0. Have fun!
