Example Code
DataBase: Gathering Information in a Specific Date/Time Range
Products and Environment
    Software
  • LabVIEW Database Connectivity Toolkit
  • LabVIEW
Code and Documents
Overview
This example VI show how to retrieve information from a table in database which has columns defined as Date/Time data type.
Description
This example has been tested with Microsoft Access 2013 and the most important is that you can retrieve information from a table in database which has columns defined as Date/Time data type. The most important in this example is to show you how to build your query since TimeStamp in LabVIEW must be reformatted in order to get a Microsoft Access valid format.
This example has been built with an Event Producer Consumer structure. You can execute two specific queries:
SELECT * FROM table_name
SELECT * FROM table_name WHERE column_with_dates BETWEEN time_stamp_1 AND time_stamp_2
Requirements
LabVIEW 2012 (or Compatible)
Database Connectivity Toolkit 2009 (or Compatible)
Access 2013 (or Compatible)
  • Run the Vi
  • If necessary, modify query parameters
  • Retrieve all data or Execute query and look at the results
Additional Information or References
VI Block Diagram
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
Comments
HunterSeeker
Member Member
Member
on
Thanks for posting, Great Example
Hunter
ssingh1
Member
Member
on
unable to open in LV 8.2
