Overview
This VI decouples a signal from time when using the simulate signal Express VI.
Description:
This VI decouples a signal from time when using the simulate signal Express VI. Since the output of the Express VIs is Dynamic Data you have to use the Convert from Dynamic Data VI before you can Get Waveform Components and then bundle them together. Also included in this VI is a simple combined graph of the two arrays to show a simple application.
Instructions:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
Hardware
