Overview
This examples gives a delayed response from a user selected boolean control to its indicator
Description
This VI will give a delayed response from a user selected boolean control to its indicator. There is also a counter present in the VI that shows that the VI never slows down while using the Elapsed Time VI. The amount of time elapsed can be set by the user for varying applications. The Elapsed Time VI also has an auto reset that the control is wired to.
Requirements
LabVIEW Full Development System 2012 or compatible
Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Hello
I am having trouble with this time delay component. After applying the time delay into the VI file l cannot run the circuit for testing. However after removing the time delay l can run my circuit. l have a hint that when downloading this LabVIEW software l might have missed a file. Is their anyway to check what files might l be missing to find th emissing file. Or if anyone has another suggestion plz let me know.
