Example Code
Delayed Continuous Waveform Acquisition with Producer Consumer
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
The example is to demonstrates the delayed version of the acquired data with the input from the user (software delay)
Description:
Upon the acquisition of the analog input, we could implement a software delay to the VI and using the producer and consumer pattern. With the delayed version in the consumer loop, the time would then added by the number of the desired delay and eventually could be stopped by releasing the queue itself.
Steps to Implement or Execute Code:
To implement this example:
  1. Define the Physical Channels
  2. Set the desired delay
  3. (Optional) Set the value of the rest parameters as needed
  4. Run the VI
  5. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the AI features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Analog Input Module
Kaitlin N.
