Overview
Code that will enable you to programmatically erase a file from a folder.
Description
This VI will allow the user to decide if a file is deleted from the directory specified in directory path that matches what is specified in a pattern. The pattern matching this function performs is like that used in matching wildcards in DOS and UNIX file names. If you specify characters other than the question mark character (?) or the asterisk character (*), this function lists only files and directories that contain those characters. You can use the question mark character (?) to match any single character. You can use the asterisk character (*) to match any sequence
of one or more characters.
Requirements
LabVIEW 2012 (or compatible)
1. Enter the full path of the directory in which to search.
2. Enter a pattern to search for within the directory.
3. Run the VI.
4. Confirm or cancel the delete operation for each filename found.
Additional Information or References
Dan King
