Example Code
Determine Largest Particle in Particle Analysis Report
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to determine the largest particle from a particle report generated by the IMAQ Particle Analysis Report VI.
Description
The VI can be given a minimum size, which will be compared to all particles in the report to check if any of them meet this size requirement. If no particles are found that are greater than or equal to the minimum size, the Object Detected? indicator will be false. Along with the largest particle's area and center of mass being reported, a bounding box is created (size 50 x 50 pixels) that can be sent to an IMAQ Overlay VI.
This VI is meant to be used as a subVI in another VI's block diagram. A test VI is attached to demonstrate how to do this.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware required
  1. Download and extract the attached file "Get Largest Particle from Particle Analysis Report LV2012 NIVerified.zip"
  2. Open both VIs and follow the instructions in Front Panel and Block Diagram and run the program.
  3. You can use the "Main Test VI LV2012 NIVerified.vi" that demonstrates how to use the "Get Largest Particle from Particle Analysis Report LV2012 NIVerified.vi" as a SubVI.
Additional Information or References
Get Largest Particle from Particle Analysis Report LV2012 NIVerified.vi - Front Panel.pngGet Largest Particle from Particle Analysis Report LV2012 NIVerified.vi - Front Panel.png
Get Largest Particle from Particle Analysis Report LV2012 NIVerified.vi - Block Diagram.pngGet Largest Particle from Particle Analysis Report LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
shreya111
Member
Member
on
Please convert it to LabVIEW 2012 version.
Poolean
Member
Member
on
Done! It's now included as an additional attachment.
