Example Code
Determine if the Windows Environment is 32-bit or 64-bit Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI uses parses the string output of the System Exec VI to determine if the Windows Environment is 32-bit or 64-bit.
Description
The System Exec VI is called with the command "wmic os get os architecture", which returns:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\>wmic os get osarchitecture
OSArchitecture
64-bit
C:\>
This string output is then parsed to return the "32" or "64" and highlight an appropriate LED on the front panel.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI.
  2. Check the lights to see if it is 32/64 bit OS
Additional Information or References
 VI Snippeto of Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Rick C.
Comments
CMarco
Member
Member
on
The above snippet is good, but it fails for example for OS win 10 that has a different reply to command "wmic os get os architecture". I suggest this more general implementation with Regular Expression:
