Overview
This example demonstrates how to measure the period and frequency in response to different aperture and settling time configurations.
Description
Even though there are benchmarked values for certain digits of resolution in the DMM specs, it is possible to set your own aperture time and settling time in order to achieve a particular reading rate. Using the niDMM Get Measurement Period.vi, we can determine the measurement period based on a certain aperture time and settling time that we set with the niDMM Property Node. By taking the inverse of the period, the reading rate can be determined.
Requirements
Software
LabVIEW 2012 (or compatible)
NI-DMM driver which is compatible with your hardware and version of LabVIEW
Hardware:
NI DMM Device
1. Select the Device Name
2. Select the measurement type
3. Configure the range and resolution
4. Run the VI
Additional Information or References
