Example Code
Determining the Termination Status of a TestStand Execution
Products and Environment
    Software
  • Teststand
Code and Documents
Description
Overview
This example shows how to check the state of the execution, and change the behavior based on whether the execution is terminating.
Description
When you terminate a TestStand execution, the Cleanup step group for each executing sequence is still run in order to ensure that any shutdown code that may be present is executed.  In some cases, you may need to change the behavior of the shutdown code based on whether the execution is terminating or running normally.  To accomplish this, check the value of the following property:
RunState.Execution.GetStates (runState, termState)
The termState out parameter returns the current termination state of the execution.  the TestStand API Help provides detailed information of the possible values for each parameter:
TestStand API Reference Help: GetStates Method
Hardware and Software Requirements
Determining Termination Status - TS2012.seq
TestStand 2012 or Compatible
Determining Termination Status - TS2017.seq
TestStand 2017 or Compatible
  1. Open the attached sequence file, and run the MainSequence using Execute » MainSequence .
  2. When prompted, either click Continue to complete the execution normally or click the termination button to terminate the execution (alternatively, navigate to Debug » Terminate Execution) .
  3. Another dialog appears, indicating whether the execution was terminated.  Since this step is in the cleanup step group, it is executed in either case.
Additional Information or References
Comments
bienieck
Active Participant
Active Participant
on
How to do the similar thing but in PostBatch callback?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
