Overview
This code makes use of microsoft DevCon to allow the enabling, disabling and restarting of devices.
Description
This application finds all hardware according to DevCon and lists them in a listbox, you can then select hardware items and perform the given actions on them if the system allows it. You need to make sure you are running the application as an administrator to perform actions on hardware. If you are running the VI in the development environment, run the development environmen as an administrator.
Requirements
Additional Information or References
VI Snippet of Block Diagram
Hi MHutch,
Could you please post a screen shot on how devcon is impletemend in your code? I really appreciate you posting Devconmini, but cannot open the LabVIEW Project File in 2012.
Thank you!
Hi InspiredTech,
Following your comment I uploaded a 2010 version of the code that you should be able to open. It is untested, but I can't see any reason why it wont function the same.
Kind regards,
Matt
Thank you, Matt
In case anyone has any questions about the line utility functions for devcon, here is another NI post concerning this same topic:
https://decibel.ni.com/content/docs/DOC-5165/diff?secondVersionNumber=3
Very cool UI's by the way. Are you a member of the UI interest group?
Thanks InspiredTech,
In my haste it looks like I didnt include everything neccessary with the 2010 version, but I should have rectified that now - Managed to find some time at the end of the day!
I can't seem to access that first link you posted, but I shall certainly look at the UI group! Thanks!
Kind regards,
Matt
Hi All,
Could someone downgrade this project to LV2010? ![]()
Much appriciated!
Andrew
Hi MHutch,
It appears that when you fixed things on March 20 the project was saved as something newer than LV2011. When I attempt to open it with 2011SP1 I get a "LabVIEW: file version is later than the current LabVIEW version" error
I know the post is getting a bit old but I would really appreciate a new build for 2010 (that way Price could be in good shape too
Dave
