Example Code
Digital Lines for Scrolling LEDs
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI will uses a digital line to move a high line across the digital channels with a trigger.  Only the active line will be high, i.e., the previous line will turn back off after the next line is high.
Description:
The example would covers a very basic use of write the digital line. With that in mind, it would have a caveat of always write without defining the maximum channel of the hardware.
Steps to implement or execute code
To implement this example:
  1. Run the VI
  2. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the DIO features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Digital IO Input Module
Jim Schwartz
