Example Code
Digitize graphs and plots
Code and Documents
This LabVIEW 2009 project + executable contains the VIs to convert graphs and plots to text files. The digitization is manual, but very practical.
In the first two steps, set the x-axis and y-axis scales. Third, trace the line you want to convert. The digitized data is automatically saved to a text file in the same directory.
Contributors
