Example Code
DirectShow .NET LabVIEW SDK (Video, Audio, IP streams)
Code and Documents
Inspired from LabVIEW portal - reference link
Library and examples provided as is, minor bugs (aka. features) included but still can be useful for someone who needs to acquire, compress and edit video/audio streams from various sources, directshow compatible devices and internet streams.
Works with GigE cameras if manufacturer provides directshow compatible filter. (Tested with Basler family).
DirectShow has a steep learning curve but once you get familiar with GraphEdit then samples from internet and examples from below should be sufficient to create sophisticated applications.
To back check your LabVIEW creating add
Wire it to your FilterGraph and open in GraphEdit program for inspection and debugging.
Requires:
Microsoft Windows SDK - download
Directshow.net library - download
DirectX.Capture class library - download
References:
MSDN DirectShow documetation
DirectShow Debugging/ConceptProofing Tools:
GraphEdit (Microsoft Windows SDK)
Alphabetical and Numerically Logical String Array Sort for user menu facelift
BEFORE Opening any vi make sure you have in the same directory:
DirectShowLib-2005.dll
DShowNET.dll
DirectX.Capture.dll
logicalstringarraysort.llb
Great links:
H.264 CUDA Encoder directshow filter -> Examples Added 02/16/2013
Directshow virtual video capture source - aka printscreen
Other articles from Maxim Kartavenkov
02/16/2013 Update
H264Encoder requires:
  • BaseClassesNET.dll
  • H264Encoder.dll
I went with wrapper mode implementation. Check Maxim Kartavenkov forum for details.
H264 CUDA Encoder directshow filter example can be done entirely in BaseClassesNET.dll. Which might be done one day...
No error checking on CUDA capabilities.
Use with Nvidia GPU's only
Examples:
  • Capture Video and H264 CUDA.vi
  • Render Media Stream.vi
Updates to Library:
  • Add H264 CUDA Filter.vi
  • Create AviMux.vi - overrite file option added
  • Enum Pin Media Type.vi
  • Enum PinMediaTypes.vi
  • Enum Pins.vi
  • Free PinInfo.vi
  • H264 CUDA Get Filter Options.vi
  • H264 CUDA Set Filter Options.vi
  • H264 Object Wrapper.vi
  • H264 Settings.ctl
  • Media Mode.ctl
  • Media State.ctl
  • MediaFormatType to String.vi
  • MediaSubType to String.vi
  • MediaType to String.vi
  • AMMediaType to String.vi
  • Picture Snap (32-bit RGB Image).vi - updated auto init
  • Picture Snap (DIB Image).vi - updated auto init
  • Set Sample Grabber.vi
  • WaveFormatEx.ctl
  • Capture.vi - updated to reflect above changes
  • Minor tweaks
02/07/2013 Update
Examples:
  • Acquire Video.vi
  • Acquire Audio.vi
  • Acquire Video plus Sample Grabber.vi
  • Capture Video.vi
  • Capture Video with Preview.vi
  • Capture Video with Preview and Sample Grabber.vi
Updates to Library:
  • Release Object.vi
  • Init Capture Preview.vi
  • Configure Capture plus Preview.vi
  • Configure Video with Sample Grabber.vi
  • Media Control - StartStopPause.vi
Updates to Capture.vi
  • Preview in Capture Mode
  • Proper Objects release upon start/stop/exit
Update 10/08/2014:
DShow - JPEG dump example.
-Artur
Comments
Cepera
on
GriffinRU and everyone:
I've been using this library for a while with LV 2017 32-bit on WIn 10 and 11 64-bit, and it works very well. If anyone is interested in my proof-of-concept application, you are welcome to try it, it's called Airplane! SnV, and you can find it here.
Now I am trying to use this library with LV2023 Q3 64-bit, and so far, no luck. (I did replace DirectShowLib-2005.dll with its 64-bit version from SourceForge, but I did not find 64-bit replacements for DShowNET.dll and DirectX.Capture.dll. Not sure if they are being used though).
Has anyone ported these libraries to 64 bits? Any advice? Thanks!
anhduy92
on
I am sorry for re-up this old post but I don't know where to download these following DLL files:
  • H264Encoder.dll
codeproject.com can not be accessed anymore. I could not find any other sources for downloading.
Thank you so much for any help.
Contributors
