Overview
This example demonstrates several VI Server properties of Tab controls. It shows how to enable/disable a specific page of the tab control and how to programmatically toggle between pages.
Description
There are times that you would want a tab to show, but not allow the user to select the tab until other actions have occurred, such as submitting data points. You can access this property through a property node.
Requirements
LabVIEW 2012 (or compatible)
1- Download the attached zipped folder
2. Open the Project and run the Disable tab control VI
3- Enter your configuration on Parameters Tab & click Submit
4- Check Results and click on Finished.
Additional Information or References
Block Diagram
Front Panel
downloaded, opened, viewed BD, understood, tested - worked!
example code as it should be ![]()
Well written example.
Very nice example, thanks
