Description
Description-Separate-1This example will show how to display hexadecimal string and normal string together in a table. If you have input from hexadecimal display string control and normal display string control, and you require to display them in a table, this example can provide some idea. In this example, 16-bits are used for the hexadecimal as an example. You can change the numeric representation connected to the Type Cast function to achieve display for different bits.
Below is the expected result for this example:
Below is the snippet code of this example:
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project. To use a snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW diagram.
Description-Separate-2
