Example Code
Display all quadrants of a Compass Plot
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to center a 2D Compass Plot.
Description
By default, a LabVIEW compass plot only displays those quadrants of the polar coordinate system that are needed to display the vectors passed to the function. There is currently no available setting to display all four quadrants by default.
Therefore the example adds four vectors with appropriate length that reside on the X and Y axis in positive and negative direction. With these extra vectors all four quadrants are needed to display the compass plot completely.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Open the attached file
  2. Select if you want to center the Compass Plot
  3. Specify the vector you want to plot
  4. Run the VI
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Caleb Harris
National Instruments | http://www.ni.com/support
Comments
Ddrizzle
Member
Member
on
Has the compass plot been updated to display all four quadrants?
