Working in the Lab, we often want to sample channels at a very high rate, however sometimes, whether it be to reduce the file size or smooth out noise on the channels, we would like to average the data.
I created a simple VI that takes as its input a 2D array and an integer.
The VI takes the input array and averages N samples on each row of Data and ouputs the values into a new 2D Array.
Currently my data is saved where each channel occupies a row. With a small amount of rework (transposing the input array) this VI could work in instances where each channel occupies a column instead.
The output array has a number of columns equal to the number of input columns divided by N, where each new value is an average of N old values.
