I want to duplicate multiple rows of the Listbox in LabVIEW. For example, I going to select 3 data in Listbox and duplicate these data. However, I’m able to extract the first selected row number from the property node (Focus Row) but not the second and third data.
How-Separate-2
If the array indicator connects to <Value> properties of Listbox, it will show the selected data row index array. However, if there's a Listbox indicator will show the selected data as Listbox controls.
Since the array index number is started from 0, so the desired position of the duplicate data should always -1.
For example, if want to locate duplicate data on the top of the Listbox, the index number of the Insert into the array should be 0.
If the first and second elements were selected and duplicated, then these data were inserted into position after the original first data. The index number of the insert into the array should be 1.
