Example Code
Dynamic creation of right click User menu for control
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI Demonstrates how to dynamically create right click user menu for one control or indicator.
Description
It is easy to create one user right click menu for control (or indicator) in edit mode. But this menu is static and can't evaluate during time.
This example show you how do that with events and how dynamically modify it.
Note: Like menu is dynamically created, it isn't saved in control (like in edit mode) and is completely recreate each time you right click on control. For this reason, it is unnecessary to delete user menu items between two right click actions.
Requirements
  1. LabVIEW 2012 (or compatible)
  1. Run Vi.
  2. Right click on "Cadran" and you obtain traditional Application Menu.
  3. Set Menu Type to User.
  4. Right click on "Cadran" and you obtain dynamic User Menu.
  5. Play action, and try again.
Additional Information or References
VI Snippet
