Example Code
Dynamically Change Acquisition Parameters in VBAI
Code and Documents
Overview
Demonstrates how to dynamically adjust image acquisition parameters based on the results of analysis performed downstream in the inspection process by making use of variables in Vision Builder for Automated Inspection (VBAI).
Description
When setting up an image acquisition step in VBAI, you normally adjust the camera parameters and then go about creating a script to perform a task. Since many vision processing algorithms are very sensitive to lighting conditions, the environmental lighting has to be strictly controlled for predictable algorithm results, or the inspection must be modified to account for the change in lighting conditions.
Many users assume that you will have to change these parameters manually every time the environment changes, but it is possible to update the acquisition parameters based on the results of an inspection step. This allows your application to respond to changing environmental conditions without direct user input.
Hardware and Software Requirements
  1. One of the following types of cameras:
    • Gigabit Ethernet Cameras Supporting GigE Vision
    • FireWire IEEE 1394 Cameras
    • USB 2.0 Cameras Supporting Microsoft DirectShow
    • USB 3.0 Cameras Supporting USB3 Vision
  2. Vision Builder Automated Inspection 2015 or compatible
  1.  Connect compatible camera to the computer
  2.  Run this inspection
Alyssa H.
Contributors
