Example Code
Dynamically Retrieve Real Time Target Directory and INI File
Products and Environment
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to retrieve a list of directories and single files from a real-time target using FTP protocol.
Description
This program shows how to dynamically retrieve the contents ("FTP Directory Listing.vi") of your Real Time Target. After getting the directory list the example can also retrieve the contents of the "ni-rt.ini" file or any other file and save it to the host machine using the "FTP Retrieve Multiple.vi". The "FTP Retrieve Multiple.vi", can retrieve any file stored on your Real Time Target.
Note: On newer NI Linux Real-Time targets you need to install Legacy FTP Server in order to use this example.
Requirements
 Software
  • LabVIEW Full or Professional Development System 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible) for target application
 Hardware
  • NI Real-Time target (e.g. 9024 or compatible)
  1. Download and extract the attached file "Retrieve List of Directories and files using FTP LV2012 NIVerified.vi"
  2. Open VI and follow the instructions in Front Panel and Block Diagram and run the program.
Additional Information or References
Retrieve List of Directories and files using FTP LV2012 NIVerified.vi - Front Panel.pngRetrieve List of Directories and files using FTP LV2012 NIVerified.vi - Front Panel.png
Retrieve List of Directories and files using FTP LV2012 NIVerified.vi - Block Diagram.pngRetrieve List of Directories and files using FTP LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
A_Ryan
AES
Comments
HunterSeeker
Member Member
Member
on
Could you reload a picture of your VI, with all of the VI labels turned on, it would make the picture much more useful
Hunter
Todd S.
NI Employee (retired)
on
looks great! thanks for posting!
Todd S.
LabVIEW Community Manager
