Overview
Demonstrates how to dynamically retrigger custom stimulus in LabVIEW Control and Simulation.
Description
Here is a brief description of the example:
The attached VI uses LabVIEW Control and Simulation Module. In order to create a custom stimulus, a 1D Look-Up table is used. This is indexed with respect to the Simulation Time. The resulting behavior is that the Look-Up Table is sequentially output over time. In order to regenerate the stimulus, a boolean is used to latch the retrigger time. The retrigger time is subtracted from the current time in order to start the Look-Up Table output sequence again.
Requirements
Additional Information or References
VI Snippet
