Overview
This example VI show you a thermometer which can display the result in different way based on the input value.
Description
This VI is a thermometer which can display the input temperature value in different controllers. Depending on the value you input, different Boolean controller having different color will appear to give the tips. Because of using the while loop, so you can change the input at anytime.
Requirements
Additional Information or References
VI Snippet
We tried to give temperature input from an external device by serial portreading using an USB.But tried by manually giving input to thermometer for study and the system worked.
