Example Code
Edge Detection with Decimation
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to add decimation to Edge Detection.
Description
This VI will detect edges on a digital signal and trigger on rising-only, falling-only, or both. Triggering can be decimated to require N triggers before providing an external trigger. Can be used inside a single-cycle timed-loop.
Requirements
LabVIEW 2012 (or compatible)
1. Set the desired number of edges and mode.
2. Select the Run button.
3. Change the mode and see the update on the graph.
4. Stop the VI with the Stop button.
Additional Information or References
