Easy way to Edit/Type (Using Keyboard) Contents in MCL (MultiColumnListBox) during Run Time
This VI creates an event based on Mouse Down on the MCL and Gets the Co-ordinates, use Point to Row Column Invoke Function to get selected Row Column and Use this Row Column values for Edit Position Property Node
LabVIEW Version above LV2010 (Even Lower Version will support)
1. Open the VI
2. Run the VI and Click on the Left side of the cell where you want to type the text (Right Side of the cell is not enabling properly safer to click on the left side)
3. Check whether you can able to edit /type contents to the cell.
4. Stop the VI
