Overview
If you need to change the text of a command button, text message, or other label at run time, you can use the SetCtrlAttribute function. If you need multiple lines in the text, use the special character "\n" to insert a new line, such as in the following line:
SetCtrlAttribute (panelHandle, PANEL_INSERT, ATTR_LABEL_TEXT, "Press\nthis\nbutton");
Description
This example demonstrates how to change the label of a command using a callback function. The SetCtrlAttribute function allows the user to edit many different properties, but in this example the Label Text property is selected. Clicking the button toggles the label from one line to three.
Requirements
Software
LabWindows/CVI
Additional Information or References
For more information on new lines in text, see the KnowledgeBase article How Can I Create Multiple Lines in CVI Command Buttons?
