Overview
This software performs the calculation and the simulation of the screw Eigen Value. It allows the user to set many types of values (radius, density, axial force, constrain type, section type, etc) and modify them as the program runs.
Special Thanks to: Umbra Group Aerospace, www.umbragroup.it
Description
This VI is designed to perform calculations and simulate the screw Eigen value. You can change many parameters, including Material Density, Length (mm), constrain type, section type, and axial force. If you want to activate the simulation, turn on the "Simulate" switch and enable the switches on the bottom left to view a simulation based on your input parameters.
Requirements
Software
LabVIEW 8.0 or later
Additional Images or Video
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Eigen Value Analysis
Very simple to use!!
