Example Code
Ensure Only One Switch of Array Control is On at a Time
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Use an event structure to control that only one element of boolean is on at any given time.
Description
The attached code uses an event structure to monitor an array of boolean switches for value changes. Whenever a value change is detected, the event structure executes a case to reset the switch that was previously "on" to "off", so only one switch will be "on" at any point in time.
Note that this does not take an initial "all off" state into consideration.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI.
2. Switch the boolean controls, and notice that only one is On.
3. Stop the VI.
Additional Information or References
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
