Example Code
Error -2146827284 When Trying to Write Text to Excel Spreadsheet
Products and Environment
    Software
  • LabVIEW Report Generation Toolkit
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Description
I spent too much time figuring out what causes error -2146827284. To spare you the time to figure this out yourself, this is what I found out:
Goal:
Export some data from a SQL database and write it into a Excel spreadsheet
Issue:
The VI "Append Table to Report.vi" returns error -2146827284
Cause:
It turns out if you want to write a string starting with an "=" (equal) character followed by more characters, not forming a valid Excel formula, this returns error -2146827284.
Possible Solutions:
- Replace the "=" (equal) character
- Prefix the "=" (equal) character with a single quote (')
Comments
crossrulz
Knight of NI Knight of NI
Knight of NI
on
Well, for Excel "=" marks the beginning of a formula.  You then went on to put in an invalid formula.  Use '= instead to state to Excel that you are entering a string that just happens to start with "=".
Contributors
