Example Code
Error Logging VIs
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This is an example that can log the status of the error cluster to聽 disk from LabVIEW or LabVIEW RT.
Description:
This VI demonstrates how to use ActiveX methods to save a Word or Excel report as a PDF. This can be useful for generating reports that cannot be edited by the end-viewer. This VI saves the file as "LabVIEW Save.pdf" in the same directory as the source report. You could easily modify this VI to be used as a subVI with the file name of your choice.
Requirements
LabVIEW 2012(or compatible)
  1. On the front panel,specify the file path for the Log File
2. Enter a comment into the Data to Log string control if desired
  1. Run the VI.
Additional Information or References
VI Snippet
Overview:
Description:
Requirements
  2. 2.Enter a comment into the Data to Log string control if desired
  3. Run the VI.
VI Snippet
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
