Example Code
Etch a Sketch in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview
This VI looks very similar to an Etch - a - Sketch. It uses the picture control toolkit to create an image and add points to update the picture with the press of a keyboard button.
2. Description
Etch A Sketch is a mechanical drawing toy invented by André Cassagnes of France and subsequently manufactured by the Ohio Art Company and now owned by Spin Master of Toronto, Ontario, Canada.
An Etch A Sketch has a thick, flat gray screen in a red plastic frame. There are two white knobs on the front of the frame in the lower corners. Twisting the knobs moves a stylus that displaces aluminum powder on the back of the screen, leaving a solid line. The knobs create lineographic images. The left control moves the stylus horizontally, and the right one moves it vertically.
3. Requirements
  • NI LabVIEW Base Development System 2012 or compatible.
4. Steps to Implement or Execute Code
  1. Download and open the example VI.
  2. Run the VI.
  3. Click F1, F2, F7, or F8, to draw in the board. You can also use the boolean buttons.
  4. Press the Shake button to reset the drawing.
  5. Press the Stop button to finish execution.
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Sincerely,
Jason Daming
http://www.ni.com/support
