Example Code
Event Structure combined with property Value (Signaling) example
Code and Documents
Post in primo piano
Turn on and off the light has never been so complicated!
Simple example about the use of event structure combined with property Value (Signaling).
Buttons upstair and downstair represent two light switch. Clicking on them, the respective light come on or off. If you hold a button for 1 second both or the other light come on or off. If you hold a button for 3 seconds you can control the light of the opposite side.
Post recenti
Requisiti hardware e software
Passaggi per implementare o eseguire il codice
1.
Ultimo post per
Contributors
