Overview
Coding that exemplifies how to generate a graph of the harmonics vs the THD percentage of a simulated signal.
Description
Visual aid is always a plus to analyze data. On this code we will generate an XY Graph with THD information for all the different harmonics.
Requirements
LabVIEW 2012 (or compatible)
1. Set the frequency, amplitude and the amount of desired harmonics.
2. Run the VI.
Additional Information or References
Front panel
Block diagram
do they count automatically the THD value..??becasue basd on my understanding...for first harmnic..it is a fundamental amplitude..not THD value..then, we need to calculate it based on the THD calculation...am i right??
