I use ensemble empiric mode decomposition (EEMD) to analyze respiratory signals I acquire in LV. This technique is amenable to parallel execution,
but is very time consuming. To speed up the code, I moved it into Visual C++ 2015 using Concurrency::parallel_for. (E)EMD decomposes a signal into independent modes,
and the number of modes is unknown prior to completion. Rather than allocating an enormous array to hold the result, the DLL returns each mode
in a User Event. The DLL illustrates a number of useful points on coding DLLs, particularly how to deal with clusters containing strings and arrays, and how to pass
structures to User Events. I have not included the EEMD code.
1) EEMD.cpp - a Visual Studio 2015 C++ program
2) pEEMD.vi - VI that invokes the DLL
3) test EEMD.vi - VI that demonstrates how to do this asynchronously so that each mode is displayed when calculated
Visual Studio 2015
LabVIEW 2016 (64 bit is required for larger data sets)
A multicore Windows machine
I used a Dell T5600 with 24 cores, which came close to real-time performance, with all 24 cores averaging 90% processor load.
The EEMD.cpp code calls a class called CEMD2, which is not included. It is assumed that the user will use the framework to call their own processor-intensive
parallel routines
Some familiarity with compiling DLLs is assumed.
