Example Code
Expand or Extract pixels in am Image using IMAQ functions
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to extract or expand a part of an IMAQ Image.
Description
This VI allows the user to Expand or Extract pixels from an Image to modify it's size.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Additional Information or References
 Expand or Extract Pixels LV 2012 NIVerified.vi - Front Panel.pngExpand or Extract Pixels LV 2012 NIVerified.vi - Block Diagram.png
Notes: The Factor can only be an Integer number
The image displays are set as zoom to fit but in the lower text you can see the actual size of the image.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
Comments
CHINA_GUANGDONG
Member
Member
on
请问,IMAQ EXTRACT这个文件要下什么软件装。谢谢!
