Example Code
Exponential Fit to detect fails on capacitor charge and discharge curves
Code and Documents
 The attached VI exemplifies the use of Exponential Fit function to detect fails on capacitor charge and discharge curves.
The "capacitor_curve_exp_fit.vi" works as follow:
1. Read curve samples from "cap_samples.bin" file. There are 2 charging curve samples, one curve ok and another with fail;
2. Create x array to be used by exponential fit function;
3. Calculate the best exponential fit curve using Leas Square, Least Absolute Residual or Bisquare fitting methods;
4. Calculate the SSE, R-square and RMSE statistical parameters that represent how well the fitted curve matches the acquired curve;
5. Calculate the distance between each equivalent point of the fitted and acquired curve;
6. Classify as approved or rejected based in the distance limit criteria.
VI screenshots
OBS: extract "cap_samples.bin" file in the same VI folder.
Contributors
