Example Code
Extract Data From Portion of Graph
Code and Documents
Overview
This example VI demonstrates the use of functions from Real-Time libraries to retrieve information from Real-Time target.
Description
This VI demonstrates how to use an event structure, property nodes, and graph cursors to select a portion of the graph and extract the data from the array. This can be useful for selecting data of interest from a larger set of data.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI " Extract Data From Portion of Graph 2012 NIVerified.vi"
  2. Run the program
  3. Move the cursors on the graph to enclose the portion of the data you want to extract
  4. Click the ‘Extract?’ button
  5. See that the "Extracted Signal" graph now shows the portion of data enclosed by the cursors on the "Original Signal" graph
Additional Information or References
VI Snippet
Daniel Hays | Software Product Management
