Example Code
Extract Plots from Multiple Channel Acquisition Using LabVIEW
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example shows a quick way to extract whichever plots you want from an acquisition configured for multiple channels.
Description
You can use NI-DAQ acquire multiple channel at the same time. This demonstration can be used to display only the plots you want, or could potentially be used to determine which plots to write to file, if needed.
Requirements
  • LabVIEW 2012 (or compatible)
  • NI-DAQ 12.0 (or compatible)
  • Select the device or physical Channels you pick.
  • Enter the sample parameters such as minimum and maximum value and sample rate.
  • Select the waveform to display.
  • Run the program
Additional Information or References
VI Snippet
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
