Example Code
FIFO Queue VI (fixed array, replace oldest) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI creates a fixed array and replaces the oldest element when it fills up
Description
FIFO is an acronym for first in, first out, a method for organizing and manipulating a data buffer, where the oldest (first) entry, or 'head' of the queue, is processed first. It is analogous to processing a queue with first-come,first-served (FCFS) behavior: where the people leave the queue in the order in which they arrive. This VI implements a FIFO queue, using fixed array which replaces the oldest elements when it fills up.
Requirements
LabVIEW 2012 or compatible
  1. Insert Maximum Array Size
  2. Run the VI
  3. Insert Number to Add and observe how the Queue functions
Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
