Example Code
FileSelect Test.zip
Code and Documents
This is a problem for FileSelectPopup that we are trying to isolateas a 32 bit program running under  Vista and Windows 7. The other contributing factor is that the Maximum Stack Size has to set to more than 540000000 bytes under these OS to cause the fault.
The file contains a distrubution kit, a c file, a prj file, a cws file and a an exe file.
Hopefully, someone can use this to figure out what is going on here.
Contributors
