Example Code
Filter Text Input on String Control for Only Alphabetical, Numerical, and Limited Total Number of Characters
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example uses an event structure to filter out certain characters.
Description
It only allow A-z and have a limited number of characters we allow in the input. This allows you to make sure that the data you entered from a control is controlled. It also disallows copy/pasting into the control.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open " String Control Filter 2012 NIVerified.vi"
  2. Run the program
Additional Information or References
VI Block Diagram
Comments
OllyT
Member
Member
on
Thanks for the code Dylan! Found it really useful.
Few points for other people looking at it. Numbers are not allowed characters (as stated above), you need to add the range of 48 to 57 to the case that is wired directly through. Also if you are trying to recreate this from scratch in your own application, remember to enable "Update Value while Typing" on the string control. If you don't do this then the maximum allowable characters will only work if you click away from the dialog box after entering each character.
Only checked the above in the 2011 version.
The day is quickly coming when every knee will bow down to a silicon fist, and you will all beg your binary gods for mercy.
