Example Code
Find Maximum Value in Array with LabVIEW FPGA
Products and Environment
    Software
  • LabVIEW FPGA Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to calculate the maximum value of an array on FPGA.
Description
The FPGA array pallete does not have the Max and Min VI that the standard LabVIEW array pallete has.
This example shows one possible implementation to calculate the maximum. The example indexs through the array and compares each value with the maximum found value. When it finds a new maximum it saves the value.
Requirements
 Software
  • LabVIEW Full Development System 2012 (or compatible)
  • LabVIEW FPGA Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open the [Main] ...VI inside the LabVIEW project and follow the instructions on the Front Panel
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Bryan H.
