Overview: Example takes signal inputs, makes the FFT, and finds the peaks in each signal.
Description:
This example takes signal inputs and makes the FFT, then finds the peaks in each signal. This example could be modified to read DTMF values or find interfering tones in a signal. You can change the data generation portion of the code and replace it with a DAQ assitant or DAQmx structure to set this up for live peak monitoring.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Use controls to play with parameters.
3. Move the red bar if the peak threshold.
4. Check the results in the Peak Locations indicator.
5. Stop the VI.
Additional Information or References:
